Arcam AVR200 s-video monitor out?
Discussion in 'AV Receivers & Amplifiers' started by mikeq, Mar 3, 2003.
Tags:
  1. mikeq
    mikeq
    Hi all,
    Just setup my stuff this weekend. I plugged the s-video 'monitor out' from the AVR200 into my panny plasma.
    I cannot see the On-Screen display for setting up the AVR200.
    I have selected the correct input on the plasma and it tells me there is no signal (the plasma is working fine, vga input works okay and there isn't anything plugged into the Composite socket).
    Is there anything I need to press on the AVR200 to get the OSD to display.
    Mike
  2. raven219
    raven219
    Mar 5, 2001
    546
    East Anglia (well someone has to live there!)
    +19
    IIRC the OSD will only display on the S-video out if there is a source pluuged into a s-video in. You will have to use the composite out instead.
    Raven
  3. mikeq
    mikeq
    Thanks Raven,
    That certainly wasn't clear in the manual.
    Mike
