arcam avr100 sub help
Discussion in 'AV Receivers & Amplifiers' started by thejag, Mar 10, 2002.
Tags:
  1. thejag
    thejag
    im thinking of buying arcam avr100 from hyperfi for £400 how much better will this be than my kenwood 5050,im also concerned about the fact that ive read countless articles concerning sub connection is this a normal connection or does it have to be connected via hi-level speaker connections as ive read.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    In an AV setup usually the line level (phono/RCA) connection is sufficient or recommended.
    This requires however an active sub, some of which also offer additional high-(speaker) level connection.
    Please check the AVR100's menu in terms of subwoofer settings before you buy, there are IMHO some limitations / quirks.
