arcam avr 300 vs denon 3805
Discussion in 'AV Receivers & Amplifiers' started by kid rock, Aug 26, 2004.
Tags:
  1. kid rock
    kid rock
    Dec 10, 2003
    316
    frankfurt germany and cardiff wales
    +9
    Does anyone know if What Hifi did a group test of these amps recently. I read in the July issue that the test was planned for the August edition which I didnt get due to Holidays.
    Kid Rock
  2. Radiohead
    Radiohead
    Dec 24, 2001
    4,405
    Amazingstoke
    +440
    Yes, and the Yamaha RX-V2400 won.
    To sum up - any of the current £1000 amps will provide you with an excellent product. For outright stereo the Arcam or Rotel amps will edge it (although I feel they're a little overpriced in any case), for pure AV work the Yamaha/Denon/Pioneer arena is where you want to be.
    You're talking about very small degrees of difference though.....
  3. ChalkyCardiff
    ChalkyCardiff
    Jul 24, 2004
    326
    +6
    The Denon is not as good in av as the Arcam. Arcam stereo performance 25% better(use your own ears).
  4. Radiohead
    Radiohead
    Dec 24, 2001
    4,405
    Amazingstoke
    +440
    I did thanks.
  5. Spoonfed
    Spoonfed
    I A/B compared these two in Stereo today.
    Source Arcam CD73 - speakers Quad 12L's
    Im still undecided.
    Analogue input to me the arcam has a slight edge on the denon..... not as much as i would have thought. I'd say the arcam a "touch" more warmth and tad more dynamics?
    Using Digital Input is a different story. The Arcam (to me) sounded the same as the CD player (i guess the same/similar DAC helps here?) The Denon's Bur Brown i did not like as much. Vocals less "full" and more layed back in their stage... overall more layed back than the Arcam... which is a bit more "in your face".... I think prefered the Arcams onboard decoding better (for stereo anyways... can't comment on multichannel)
    I have the 3805 at home now for testing. I'll A/B compare analogue/digital wtih my home setup (HTPC + pro audio card) and if its "night and day" with the analogue being the better i think i will go the denon.
    $800AUD different (and thats with a HUGE discound on the arcam $700AUD and a modest $300 on the Denon) is still a lot...... could get me improvements in other areas...
