Arcam AVR-250 and iPhone?
SP00KY
Is it possible to hook up an iPhone 3GS to the Arcam AVR-250? If so is there any particular dock that might make it easy? How things change in a very short time.... ;)
mossym
mossym
sorry, this is the iphone version of the wadia product, don't think the other one supports iphone
171i
SP00KY
Thanks for that. What sort of connection would this use, as I only remember the Arcam having phono style inputs and not the smaller inputs I usually see on things like mp3 players, etc.
mossym
for the apple one, you need a 3.5mm to twin phono cable, paces like maplin should have one
for the wadia one, you need an S/PDIF cable, can't remember if it is optical or dig coax
SP00KY
Thanks again. Wadia don't seem to be widely available - are there any other nice looking docks that could be considered? The wife wants a dock to play her music - I thought using the existing system might sound better and be quite a bit cheaper than a decent speaker dock....
SP00KY
WOW - £550 for the Wadia 171i - for a dock..... It might not make the list of possible options.... ;)
Does anyone have any other options, as that seems ridiculous.
mossym
yeah it is ridiculously expensive, but digital music from the ipodis pretty new and is expensive.
is there something wrong with the apple one i linked to? that's pretty cheap
SP00KY
That might be the way to go - I'll have a look around when I am next at the shops. She will want to simply pop it into a dock and play the music - ideally it will charge at the same time.
Druboo
these assume arcam don't have their own dock, which they quite possible could
Indeed they do Google Arcam IR dock ;)
SP00KY
I didn't spot that when I looked on their site - cheers! Has anyone used one of these and would there be any potential problems with using it on the AVR-250?
Edit: Done some more reading and it looks good and should be fine with my old amp as far as I can see. If anyone has any feedback about this product or others that should be considered then please let me know.
