Arcam avr 135/137 Vs. ADCOM GDV-870
D
dhoffacker
I was wondering if anyone has compared these products. The adcom looks like a killer deal at 600$ us, with the same dacs and video processor as the arcam 135. Any thoughts would be appreciated.
Current setup: Arcam avr 350, fronts: spendor s5e, center: spendor C5e, rear: spendor: S3e, sub: velodyne spl-1000r.
I need a new dvd player, I just have a panasonic dvd recorder, which as a transport with the arcam dacs sounds decent, but I need to buy a new dvd/cd player.
Thanks,
Dan
ADCOM GDV-870:
"Reference quality performance is assured by the superlative Zoran VADDIS 888 Video DSP for optimum video fidelity and the discrete Wolfson 8740 24-Bit/192 kHz DAC in each audio channel is used in a noise-canceling, balanced configuration for superior audio quality and high performance DVD-Audio operation. Audio, bass and delay management is fully configurable.
The GDV-870 also employs a Hybrid Power Supply: Digital for high-current servo circuits and High Performance Linear with massive Toroid Transformer for low noise video and exceptional audio performance."
http://www.adcom.com/prod/shopdisplayproducts.asp?prodid=1313
webhammer
Established Member
Off-the-shelf parts are relatively cheap. Arcam uses the 888s processor, not the off-the-shelf 888, and the 888s is specially designed to their demanding performance specifications. The proof is in the performance, I suggest finding dealers willing to let you try the units in your system and make the choice yourself.
🎬 The Top 20 Most Anticipated Movies of 2024
Back
