Arcam AVR-100 Owners Please Read
Discussion in 'AV Receivers & Amplifiers' started by Dorian, Aug 9, 2001.
Tags:
  1. Dorian
    Dorian
    May 2, 2001
    537
    Lancashire
    +44
    Sorry to repost a question but I want to get to the bottom of this :
    I have an AVR-100 with a hum in the centre channel speaker (which I must admit is very quiet) and clicking noises through the rear L/R channels caused by changing volume using the remote.
    Is this normal for an AVR-100 or should I return it for repair/replacement ?
    <br />Thanks,
    Domino
  2. AVMAN
    AVMAN
    Send it back mate,just to be on the safe side.I dont own one but i sell them and demonstrate them and ours dont do it.
  3. gatesy
    gatesy
    I too had a 'quiet' hum from the centre speaker. Arcam fitted a ferrite ring to it which sorted this out. I didn't have the clicking you mentioned though. Arcam support are top blokes and will help you out if contacted.
    Cheers,
