Arcam AV9?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by JetJockey, Oct 11, 2004.
Tags:
  1. JetJockey
    JetJockey
    Hi Folks.
    Got to ask, and no I don't have any inside information.
    Are Arcam working on anything new in the processor department at the moment, which might be released in the coming months? I am particularly thinking of the HDMI switching side of things. I am also told that the AV8 does not do DTS 96/24 decoding but don't know what the full implications of this might be.
    Any help much appreciated.
    Thanks, G. :)
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    DTS 24/96 is worthless, simply so few discs it is largely an irrelevance
    Arcam will let people know when they release a new products and not before. However their DVD players do support this new format but the current state of the silicon is that you can now have a HDMI output that fully complies to HDMI spec but not yet a HDMI input that fits the HDMI full spec, the silicon just doesn't exist yet. When it becomes available…….
  3. JetJockey
    JetJockey
    Thanks Beekeeper.
    Looks like the AV8 might not be a bad investment then? :confused:
    Thanks, Gerald. :)
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    AV8 is the class leading bit of kit IMHO, I would certainly be happy if I had made this purchase
