Arcam AV8 question
Discussion in 'AV Receivers & Amplifiers' started by jeroen999, Jan 8, 2003.
Tags:
  1. jeroen999
    jeroen999
    Dear People,
    I have i question hope someone know's
    When the Av8 is set on sat+sub in the menu .
    And you set the sub at 60 herz,will this mean that the al the satelit spaekers will not go under the 60 herz?
    And is this for all speakers including the center?
    And what about the speakers that are set on Large will these not be affected when changing the sub frequency?
    hope someone know's
    greetings jeroen
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Do you mean a) you adjust the frequency at the sub itself or b) at the amp?
    Generally the cut-over frequency set in the amp will usually only effect those speakers set to SMALL. If e.g. the frequency is set to 60Hz than all frequencies below 60Hz to this speaker are cut off and will be send to the subwoofer out instead, given that the sub is declared as YES (else the lower frequencies will be routed to the fronts).
    Different manufactures may implement those rules differently however.
  3. jeroen999
    jeroen999
    I mean, when set on the amp.
    thank's fot your reply!
    But do you know if the AV8 does this in stereo and 5.1.
    And if you have small speakers 13cm woofer (8Liter)
    would you set it on small or just send a full signal?
