Arcam AV8 progressive scan question
Discussion in 'AV Receivers & Amplifiers' started by BLACK_MAGIC, Oct 10, 2003.
Tags:
  1. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    601
    manchester
    Does the arcam AV8 recognise PAL progressive scan if i plugged a dvd player with PPS into the back of the arcam (hi component cable) and then from the AV8 into a TV/Plasma/Projecter that supports PPS or would i run into any problems?
    Thanks those that help.
  2. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    I'm under the impression that it does, but I'll give mine a try tomorrow to see how it goes.
    Regards
    John
  3. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    601
    manchester
    Thanks let me know how it goes
  4. jont
    jont
    Apr 8, 2002
    4,197
    near Aylesbury
    +528
    The AV8 will pass through the progressive scan no problems ... thats what I do with my Arcam DV27 > AV8 > panny plasma ... my dvd player also allows for an audio delay in progressive scan output and I can further compensate on the amp (if required for other sources) ... great bit of kit :)
    Jon
  5. Edgeyboy
    Edgeyboy
    Jul 31, 2000
    3,412
    Norfolk
    +168
    The component inputs have more than enough bandwidth to cope with Pal Prog.
    It works fine.
    Tom.
  6. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    601
    manchester
    Cool thanks people:)
