Arcam Alpha 9 v NAD C352
Discussion in 'Hi-Fi Stereo Systems & Separates' started by GW43, Mar 9, 2005.
Tags:
  1. GW43
    GW43
    Feb 27, 2005
    1,662
    63
    Out of my mind on dope and speed
    +169
    Any thoughts on which would be best? Used mainly for music (rock, indie etc.), although DVDs and the telly get plumbed through from time to time.
    I like the Arcam sound from my old Alpha 5+. The Alpha 9s on E-Bay are going for around £250-270 plus postage, whereas the NAD C352 is around £300 new, so there's nothing in the price, and power outputs are about the same.
    So - what's best? New NAD, or 4-5 year old Alpha 9?
  2. wokeye
    wokeye
    Apr 15, 2003
    806
    +100
    If it was me I would buy the new NAD. I have trouble with my Alpha 9 crackling etc when I alter the volume, or change scource position. Probably just needs serviced, but my mates also does the same. Never heard a NAD amp so I cannot comment, but I think £300 is expensive for the an old Alpha 9 amp, mine only cost me £499 about 7 years ago new, so £300 sounds a bit of a rob to me. Arcam gear seems to keep its money well if it was japanese it would be worth peanuts. Just my opinion, others may differ!!
  3. GW43
    GW43
    Feb 27, 2005
    1,662
    63
    +169
    Thanks Wokeye
    I have seen your comments about the volume pot and selector switch repeated by other people, so perhaps its a common problem with this model. My 9 year old Alpha 5+ is fine in this regard, so it may be model specific.
    I agree the prices seem high, but I've tracked several on E-bay and that's what they're making.
    I'm having a bit of a re-think anyway, and looking at an A65 and then adding a power amp later for bi-amping. A 2nd hand P75 of older Alpha power amp would be ok - no volume controls or selector switches to worry about!
