arcam alpha 8 amp manual
Discussion in 'Arcam Owners' Forum' started by parker175, Jan 26, 2005.
Tags:
  1. parker175
    parker175
    Hi all, i'm looking for a manual for my alpha 8 integrated amp, the arcam homepage only lists new kit, there is a specification page for the alpha product range, but no downloads.
    does anyone know where i can download a manual in pdf format or other?
    thanks in advance for any help,
    Bri...
  2. Commited
    Commited
    hey - what do you need to know?
  3. parker175
    parker175
    Hi, need to know how the switchable phono works, on this amp you can switch
    the phono to become a line in...theres a little blue button which needs to be
    switched, i'm in the process of buying a turntable and need to know if the phono is MM or MC, and what position the button needs to be set at...
    cheers
    Bri...
  4. Shaka
    Shaka
    Jul 26, 2004
    724
    Glasgow
    +39
    I had a quick search for you and found this on a review for an Alpha 8R amp which states:
    Guess there's your answer. Alpha 8R and Alpha 8 are similar models.
