Arcam Alpha 7 speaker outputs
Discussion in 'AV Receivers & Amplifiers' started by Mylo, Oct 28, 2003.
Tags:
  1. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    With the absence of 4mm banana sockets are spade connectors the only alternative. The cables I wish to connect are 7mm diameter. :eek:
    The binding posts look like something hollow could plug into them, but I don't know what?:(
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,944
    2
    +3,311
    Its called Camcom and I don't think that Arcam do them anymore. Perhaps the indefatigable Mr Dawson may be able to help you. In addition, I shall contact my brother (who has some single wire with some camcoms on the end) and see if I can sort something out. I'll PM you if I have any luck.
    Ed
  3. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Thanks, Tons.:)
  4. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
    It is possible to use banana plugs on the Arcam through the holes exposed if you unscrew the terminals. If you do this just be careful that the plugs don't touch anything they shouldn't, it can be a tight squeeze.
  5. Lintone
    Lintone
    I have some camcons........ how many do you want??? PM me on the address below
    Regards,
    Mark
    info@lintone.co.uk
