arcam alpha 7 amp - where get a manual? bi-wire help req'd
Discussion in 'Arcam Owners' Forum' started by ss116, Jun 10, 2005.
Tags:
  1. ss116
    ss116
    Jun 10, 2005
    5
    Hi.
    Just obtained an arcam alpha 7 amp.
    Would like a manual..
    Is there a source for one..?
    I had bi-wired speakers that were connected to twin binding posts on my last amp.
    As far as I can figure - I need to connect both pairs of my runs of cable to each speaker to each binding post on the 'direct' channels??
    Correct??
    What is the function of the 'direct' Vs 'switched' outputs??
    I presume I dont connect one run to the 'direct' and one to the 'Switched' do I??
    SS
  2. sput2001
    sput2001
    Jan 9, 2005
    401
    Manchester
    +10
    Have you tried contacting Arcam's support? They might be able to send you a manual in pdf format. When I bought my Alpha 9 amp a few years ago it didn't have the manual and Arcam just sent me one through the post for free!
  3. ss116
    ss116
    Jun 10, 2005
    5
    that's my next step I guess.
    I only got it today..
    SS
