Arcam Alpha 6+ easily repairable?
Discussion in 'AV Receivers & Amplifiers' started by bfinn, Feb 12, 2005.
Tags:
  1. bfinn
    bfinn
    I have an Arcam Alpha 6+ amplifier. Yesterday I managed to blow the right channel by accidentally shorting the left and right outputs together (blue flash followed by silence from the right channel). The left channel seems fine but the right channel does nothing. (I've checked the speakers themselves and they are fine.)
    I am no electronics expert. Am I likely to be able to get this amp repaired (relatively inexpensively & quickly), e.g. has it probably just blown a single component which can be readily replaced, or should I just chuck the whole amp in the bin and get a new one?
    And if you think it can be repaired, what's the best way of getting it done?
    Thanks!
  2. bfinn
    bfinn
    P.S. Sorry, I meant I shorted the right channel's +ve and -ve together, while carelessly waving an interconnect around. (Left channel was uninvolved in the incident.)
  3. SillySausage
    SillySausage
    Jul 10, 2004
    630
    Leicester
    +32
    Hia, Have you checked the fuses under the cover?
    I have the same amp, although not used anymore. There are two quick blow fuses , 1 for each channel and I bet one of the fuses has gone.
    I think they are something like 3 amp quick blow, but can't remember.
    They're available in packs of 10 for about 2 quid from Maplins.
    Hope this helps.
    Cheers,
    Adam.
    PS. If you have blown it up, I'll sell my 6+ for £150 ;)
  4. bfinn
    bfinn
    Thanks - the right channel fuse has indeed blown, so I'll be off to Maplin's tomorrow.
  5. SillySausage
    SillySausage
    Jul 10, 2004
    630
    Leicester
    +32
    Dammit, slipped up there... Could have sold you my 6+ :devil:
    Glad it had blown and not popped - so to speak.
    :thumbsup:
  6. bfinn
    bfinn
    Success - Maplin's sold me the exact same fuse for a mere 7.9 pence (well, 79p for 10), and now it's back working as normal! (Slightly cheaper than a new amp.) Thanks again for your help.
  7. SillySausage
    SillySausage
    Jul 10, 2004
    630
    Leicester
    +32
    :thumbsup:
    Glad it's fixed.
    Happy listening once more :D
