B
Bob Mitchum
Just purchased an Arcam A85. Just need answers to these 2 questions. if anyone can help. Regarding the fixed gain, I have set it to 69(which is quite high as 72 is the highest gain level), to match with the rest of the speakers which are connected to my AV amp. Will this cause a problem? Will it lead to the A85 cutting out?
Finally, when you go into customizing settings and go into tone controls-it gives you the option to personalise each tone setting or leave it to a global setting. If you leave it on global setting and do not put on the tone button on the fascia does that mean you are listening in source direct which I want?
Equipment: Arcam A85, CD92, Yam630, B&W CDM1NT,CDMCNT,Mission 701, Paradigm PR8
