Arcam A85 + processor upgrade
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by ronancoll, Jan 17, 2003.
Tags:
  1. ronancoll
    ronancoll
    Does anyone know anything about a DD/DTS decoder module for the A85. Does it exist and if so how much. I have recently purchased an A85 and am really happy (after the first one i got had to be sent back 'cause it wasnt working!) with it. But i have an old Yam DSP-A5 doing all the decoding duties and acting as preout for all my video sources (TV DVD SKY etc). I would like the Arcam to take over these duties and leave the Yam as a power amp only, for the rears and centre, until i can afford a P85/3.
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,631
    Newcastle
    +397
    I was under the impression that there would be a 6-channel input board that can take the output from a DV89 (or DV88+ with the DVD-audio board) which will have DPL, DD, DTS, MLP & MP3 decoding. I don't believe there would be a way to decode DPL from your TV or Sky, though.
    Cheers,
    Liam
  3. sounddog
    sounddog
    Dec 11, 2002
    3,445
    107
    Leicestershire, UK
    +480
    Are you talking about the DAVE module? If so, I believe this is no longer manufactured.
    As Liam said, there is going to be a 5.1 input board but this is primarily for DVD-A / SACD not for home cinema systems.
    Sorry, you're just going to have to stick with the Yamaha A5 for now ...
    Victoria
  4. lmccauley
    lmccauley
    Oct 24, 2000
    3,631
    Newcastle
    +397
    DAVE wouldn't fit into an A85, either - it was designed for the Alpha 10. It doesn't have a 6-channel input, which is good for me as it means I can't be tempted by the DV89...
  5. vanwel
    vanwel
    I thought the DAVE module is also available for the FMJ A22?
  6. lmccauley
    lmccauley
    Oct 24, 2000
    3,631
    Newcastle
    +397
    Oh yeah - the original FMJ models were based on the top of the Alpha range.
    Forgot about that.
  7. sounddog
    sounddog
    Dec 11, 2002
    3,445
    107
    Leicestershire, UK
    +480
    Okay, my mistake ... I knew the DAVE module was for the Alpha 10 and FMJ A22 ... just though it fitted the A85 as well.
    Victoria
  8. lmccauley
    lmccauley
    Oct 24, 2000
    3,631
    Newcastle
    +397
    OK, here's some more info on the A85 input board from John Dawson: here
  9. jont
    jont
    Apr 8, 2002
    4,330
    near Aylesbury
    +575
    A 7.1 version of the A85 will make an interesting little amp ... I went for the AV8 from my A22/DAVE and will save a little longer for the P7 ;-)
    rgds
    Jon
