Arcam A7R remote sensor
Discussion in 'AV Receivers & Amplifiers' started by Mylo, Sep 16, 2003.
Tags:
  1. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Any one know where the remote IR sensor is on an Arcam amplifier?:confused:
  2. Jimmysil
    Jimmysil
    I used to wonder that as well when I had it.:rolleyes:
    Hope you like the amp :D
    Jimmysil
  3. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Hello mate, love the amp it sounds huge ! Just need to disable the remote so it doesn't clash with the AV amp.
    Nice break?:)
  4. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,663
    Its behind the Arcam logo in the top left corner- I think.
  5. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Sweet. :smashin:
  6. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Tons of Fun, these remotes are mad. Even after covering the sensor inside the front panel with insulating tape, the remote still worked ! I assume they are using very high Frequency’s. I have had to shield it with aluminium foil, which works fine. :clap: :clap:
  7. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,663
    Yeah I remember that- my 7R would respond to the remote if the buttons were pressed in the same room. This in comparison to the Audio Note that needs the remote very deliberately pointed at it to make it go. Incidentally do you think Arcam might be interested in my 7R- its only the 35th one ever built. Oldest survivor?
  8. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Having been inside the unit and seen the quality. I think there may well be older survivors than yours. Would you really want to get rid of it?:)
  9. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,663
    It currently lives with my brother being used as a pre amp for a NAD C270 so in many regards I have already parted with it (my 16th birthday present- sniff). I would be happy to see it preserved for eternity however.
  10. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Just make sure he looks after it.;) :)
