ARCAM A22 - Discrete IR Codes wanted
endora
I am trying to customise my Pronto remote control with my newly acquired ARCAM A22 but I am missing some IR codes which are not on the remote but would be very useful to me.
Do you know if there are any discrete IR codes available for this amp? I looked on the remotecentral website without any luck.
The codes I am looking for are:
  • Power On
  • Power off
  • and the most important codes: tape/Proc on
  • Tape/Proc off
Thanks for your help.:thumbsup:
Crustyloafer
Here are the codes you need, these are for the A32 but should work fine for the A22 also.
Power On
5000 0000 0000 0001 0010 007B
Power Off
5000 0000 0000 0001 0010 007C
Tape/Proc Toggle
5000 0000 0000 0001 0010 0005
There does not appear to be discrete on or off commands for the Tape/Proc input.
endora
Thanks Crusty, I will try them tomorrow.
Shame though that there is no code for 'Tape/Proc off' as it very useful to switch from the AV amp to CD mode...
I guess I will have to find a way around.
endora
Well, I tried these codes and unfortunately they don't work.
