Arcam a22 blinking red light
Discussion in 'Arcam Owners' Forum' started by Earlyflash, Jan 10, 2012.
Tags:
  1. Earlyflash
    Earlyflash
    Dec 19, 2006
    1,887
    83
    +471
    Hi all
    I've got an arcam a22 fmj amp that suddenly stopped working. It was playing and cut out. The power led comes on green for approx one second then goes red and blinks. There is nothing on the display. I've tried turning off at power but same thing happens. I've also tried turning off both speakers (using sp1/2 buttons) but same.
    Any ideas before I take the plunge on taking it back to dealer? It'll be well out of warranty for sure.
    Thanks a million.
  2. Rock Danger
    Rock Danger
    Oct 10, 2007
    10,935
    2
    Belfast - Northern Ireland
    +4,670
    It sounds like protection mode for one reason or the other, unplug the speakers and inputs, pull the power cord out for 10 mins and try it, if it still does it, it most likely needs an engineer to investigate.
