arcam 9
Discussion in 'Arcam Owners' Forum' started by la gran siete, Jul 19, 2005.
Tags:
  1. la gran siete
    la gran siete
    Oct 5, 2003
    25,251
    West Sussex
    +1,975
    Can someone please Tell me whether the Arcam 9 can be used as a "slave " preamp connected to an HK receiver and using the receiver volkme control for both much like the Alpha 8r can?I intend connecting L/R fornts to the Arcam and the rest to the HK( including sub)
  2. Timmy C
    Timmy C
    Oct 10, 2003
    5,110
    +382
    Does it have a 'processor' button to the right of the volume control?
  3. la gran siete
    la gran siete
    Oct 5, 2003
    25,251
    West Sussex
    +1,975
    I dont know Timmy. I wanted to find out before I bought one.
  4. Timmy C
    Timmy C
    Oct 10, 2003
    5,110
    +382
    Sorry mate, I assumed you had one already! The later versions of the Delta 290p and also the Alpha 9c pre amp has processor mode so I would guess the 9 intergrated does as well. If no one else comes along with a definite answer I'll scan through some old magazines and find a review to see if it has the info.
  5. la gran siete
    la gran siete
    Oct 5, 2003
    25,251
    West Sussex
    +1,975
    Thank you :)
  6. redknag
    redknag
    May 18, 2004
    300
    28
    Wickford Essex
    +33
    Alpha 9 Integrated definately has a processor button. I use it almost every night. It turns it nicely into a 9P which matches my other 3 9P's. :)
  7. la gran siete
    la gran siete
    Oct 5, 2003
    25,251
    West Sussex
    +1,975
    Thanks for that . Ive got the chance of bidding for one in the "sales room" . In fact its a choice between that and an Audiolab 8000a . Not sure which one to go for at the mo.
  8. la gran siete
    la gran siete
    Oct 5, 2003
    25,251
    West Sussex
    +1,975
    That means it becomes solely a power amp then?
  9. redknag
    redknag
    May 18, 2004
    300
    28
    Wickford Essex
    +33
    Yep. I use a 9 & 9P bi-amped for my front speakers in non-processor mode for listening to CD. Then when I watch either DVD or sky+ in 5.1 I switch it to processor mode and turn on my other 2 9P's for the center (bi-amped) and rears. I have a seperate 5.1 processor that then just feeds all the amps. Works a treat.
  10. la gran siete
    la gran siete
    Oct 5, 2003
    25,251
    West Sussex
    +1,975
    ]Now that has completely confus :confused: ed me
  11. Timmy C
    Timmy C
    Oct 10, 2003
    5,110
    +382
    What he's saying is he uses his alpha 9 as an intergrated amp for music and by flicking the switch as a power amp contolled by his processor (or reciever in your case) for movies.
    I believe that's what you want to do isn't it?
  12. sput2001
    sput2001
    Jan 9, 2005
    425
    Manchester
    +18
    Yes, provided the HK receiver has phono pre-outs for the front left & right speakers to connect to the Alpha 9.
    The processor switch effectively turns the Alpha 9 into a slave amp that drives the front left & rights, while the HK will handle all the other channels. The HK's volume control will apply to all channels. My own setup at home is exactly that, except I have a Yamaha processor rather than an HK one.
  13. la gran siete
    la gran siete
    Oct 5, 2003
    25,251
    West Sussex
    +1,975
    Thats the answer I wanted .Only question I have left is where do all the inputs go Arcam or processor? I only ask because someone on this forum makes everything go through his stereo amp but then the sound would be all in strereo which seems to defeat the point of a 5.1 amp.
    Many thanks guys
  14. sput2001
    sput2001
    Jan 9, 2005
    425
    Manchester
    +18
    Connect your DVD Player to the HK. That will separate the sound out into 5.1 and feed the centre and rear speakers and the subwoofer. Use phono leads to connect the front left & right pre-outs on the HK to the Alpha 9.
  15. la gran siete
    la gran siete
    Oct 5, 2003
    25,251
    West Sussex
    +1,975
    Ok and my cd player can be connected to the alpha 9. :thumbsup:
  16. sput2001
    sput2001
    Jan 9, 2005
    425
    Manchester
    +18
    Sounds good to me!
