Arcam 350 and REL Q200e
Voivod
i am having a weird sub problem too
i have hooked up my Rel q200e (an active Sub)to the sub pre out of the Arcam 350
i did the speaker setup test with a decibel meter the sub works
but now
when i play a DTS dvd (Terminator Ultimate edition) the sub will barely make a sound.
the Arcam "detects" the DTS signal from my XBOX.
the XBOX is connected to the Arcam with an optical cable.
when i do the THX optimizer thats on the Terminator DVD all the speakers give the white noise
,but with the Subwoofer setup part the woofer wont make a sound
so far the sub only seems to work when the Arcam is in Stereo mode
its probably only a silly setup problem but i cant friggin find it!!!
any help will be greatly appreciated
(i posted this message in another thread of this forum but deceided id make a new thread for this problem)
(and sorry for my bad english)
TopMeTom
Isn't there a dts setting in the amps menu? I wil try and see. There is, page 14, how do you have your speakers set?
Druboo
Voivod
Thats the sub menu What about the speaker menu?
Can't play ATM as I'm stuck at work:thumbsdow . Not sure if you could still have those settings in sub menu while speaker menu is at sub 'none'
Voivod
Speaker Sizes
Front Large (KEF 104/2)
Centre Small (Dali C5)
Surr L/R Large (KEF Q15.2)
Surr Back None
Subwoofer Present (REL Q200e)
Voivod
what use would that do?
Voivod
thanks a LOT
however
the kids have taken over the XBOX so i cant change it right now
ill let you know though!!
(i friggin hope this was the answer to my problem)
i still dont get how the THX setup om the Terminator DVD got all speakers to produce sound except the subwoofer
anyway
as said ill let you know
thanks for your help
Voivod
ok
speakers set to Small
on the REL my settings are this:
Low level left connected from sub pre out on arcam
on the REL there are 2 low level connectors called "Left" and "right" and not like the manual says "0dB LO INPUT" and "+12dB LO INPUT"
mode 2
rolloff 100 Hz
Piece from rel q200e manual
The mode switch is a dual function control, it can reverse the phase for both high level and low level
inputs and it can bypass the internal filter/roll off.
Phase reversal is rarely needed but can be useful as explained in “SETTING UP” .
MODE SWITCH. Used to set phase* and to bypass crossover for Low Level input**.
Position 1 / Line: 0 degrees phase, crossover engaged low level input
Position 2 / LFE: 0 degrees phase, crossover bypassed for low level input
Position 3 / Line: 180 degrees phase, crossover engaged for low level input
Position 4 / LFE: 180 degrees phase, crossover bypassed for low level input
*PHASE SELECTION AFFECTS BOTH HI AND LO LEVEL INPUTS.
**Crossover is always engaged for Hi level input regardless of mode switch position,
bypassing is only possible for the low level input.
the complete manual can be found here....
http://www.sumikoaudio.net/rel/manuals/Q-Series-Manual.pdf
i have tried this whole deal without the Neutrik connector conected
(the Neutrik connects to the left and right speaker out)
sorry for posting so much information
i hope you can filter out the useless stuff
and thanks again for your time
TopMeTom
I'd set it at position 2 or 4, but i don't know your sub I have my monolith connected via single co-ax from the arcam into a low level input. And with the settings I said above.
How does it sound?
TopMeTom
Also you may be better off with a normal dvd player, I don't know how good the xbox is, one of my bigger sound improvements was a decent dvd player.
Voivod
the kids would kill me
and as i use it as a mediaplayer (mapped PC drive) too i wouldnt want to miss it either
Voivod
sorry
yes it does
main speakers sound a bit "detached" now though
but i guess thats simply a matter of more tweaking
but im not gonna do much more today
al that pounding is making my head hurt
when im looking at the manual of the REL it says i can connect the neutrik connector simultaneous (thank god for spellcheckers) but that will probably require even more tweaking and balancing
pffttt
even thinking about that makes my head spin
thanks for your time
Voivod
pm sent
although you can als post your settings here of course
for the other lost souls with the same problem
Voivod
i downloaded a cd with bas tracks and bass tests
called "Bass test & bass tracks"
i put them on my XBOX which is is connected through Optical cable
its scared the **** out of me !!!!!!
the bass is ok of course
but
the higher sounds are crackling!!! like a scratched cd
on my pc it sounds ok
does anyone else have a similar problem??
i have uploaded one of the mp3's to this location
*****link removed****
Dankeech
http://www.megaupload.com/nl/?d=UV4YMGCG (i hope its allowed to do this kind of stuff)
Hi Voivod,
:lesson: If this CD is copyrighted, then no and you'd need to removed the file and link. If the download is a legal free one then no problem leaving this link. If you don't know, then you need to assume copyrighted and remove the link.
Hope this helps.
Dan.
Voivod
thanks
i have that too
how do you have your Rel connected?
did you use the Neutrik connector too or only the low level connector?
Voivod
i only tried the by Rel suggsted double connection (high and low) for a few minutes.
its no good for a theatre system (i.m.h.o.)
im not to sure about the placement but im satisfied for now
its way to good weather here to fuss with it
Latest News
Disney+ confirms price increases coming in December
  • By Ian Collen
  • Published
Samsung unveils Galaxy Z Flip 4 and Fold 4 smartphones
  • By Ian Collen
  • Published
Movies Podcast: 8th August 2022
  • By Casimir Harlow
  • Published
AVForums Podcast: 8th August 2022
  • By Phil Hinton
  • Published
