Arcade Memory card
Discussion in 'Xbox Forums' started by nil102, Feb 4, 2009.
  1. nil102
    nil102
    Dec 14, 2005
    869
    43
    +95
    Just picked up an Arcade XBOX360 from Argos as gift for a relative had to open the box as you do! although I stopped short at plugging it in.I was expecting a memory card in the box as advertised but theres none included..Is this right or have I been stitched up.The box was sealed?????:(
  2. Timmy C
    Timmy C
    Oct 10, 2003
    5,626
    +569
    You may be in luck...I seem to remember reading somewhere that the newest Xbox 'jaspers' have the memory built in. Google it and see what comes up. If not then yes you've been stitched up!
  3. Timmy C
    Timmy C
    Oct 10, 2003
    5,626
    +569
  4. nil102
    nil102
    Dec 14, 2005
    869
    43
    +95
    Looks like your right..It says 256MB MO on the box whatever that means and the power brick is 150w..Thanks:smashin:
  5. DragonOfSilver
    DragonOfSilver
    Dec 23, 2005
    1,085
    48
    +73
    MO probably stands for memory onboard
