ARC Problems
Discussion in 'LG TVs Forum' started by DanDyDownham, Dec 16, 2017.
  1. DanDyDownham
    DanDyDownham
    Mar 18, 2008
    Hi there. Hoping someone can help as I’m slowly going insane. I have an lg OLED 55b6 hooked up to a marantz nr1506. I am using the hdmi ARC link on the tv and marantz and have told the tv and avr this using the various settings advised by forums. I also have virgin and a blu ray player hooked up to the avr.
    When I watch an app like Netflix on the tv and try to switch back to my ‘virgin’ tab on the tv screen the marantz decides to turn on my blu Ray player and go to that instead. I then have to press ‘cable/sat’ on the marantz to get back to my virgin but even that doesn’t always work and I often lose the signal completely or the virgin box will just turn itself off randomly.
    I’ve tried everything. I’ve tried reassigning the hdmi inputs on the marantz setup. I’ve tried the inputs on the lg itself. Weirdly the lg shows a ‘hidden’ input of “virgin (BD Player)” on the sidebar menu which doesn’t then appear when you go into the Inputs settings screen.
    I’m running out of ideas so any suggestions would be greatly received.
    Thank you in advance!
    Dan
