Aquos Freeview Not Working
lucy101
We have recently bought a new TV for the living room and have moved the smaller Sharp Aquos into another room. When doing this we have attached a sky box to the TV which is sort of acting as a freeview box but can only get channels 1, 2, 3, 4 and E4. So the freeview would be a lot better for us.
If there anyone that can help, because I am wrecking my head at how to do it because it was working in the other room!
Thank yoU! :thumbsup:
Adrian_F
There should be an Input Select button on the remote which will give you a drop-down list from which you can select DTV.
JayCee
More to the point is there an aerial outlet in the room you've moved the Sharp Tv to?
lucy101
Yeah I can get to the DTV very easily, but it isn't working. I can't get the channels to work on the freeview it comes up with nothing.
And yeah there is an ariel output lead
JayCee
Press "DTV Menu" on the remote and select Auto Installation to rescan the channels.
And if that still doesn't find any channels you need to establish there are signals coming out of that aerial point by trying a known good working TV on it.
Trending threads
