jimbob19
I have an MCE2005 pc fed via DVI to my Aquos
However I notice that using this method I loose out on the advanced Black setting , which does make quite a difference to the "blacks"
Is there any way to re-enable this on DVI or does it appear if using analogue vga ?
If not has anyone managed to produce as good a black from a PC fed DVI input ? If so what settings did you use
