APTUS1 - RGB to Component
Discussion in 'Projectors, Screens & Video Processors' started by mavice, Sep 21, 2005.
  1. mavice
    mavice
    Dec 8, 2004
    399
    Midlands UK
    +16
    I just bought a Keene APtus 1 converter to convert Sky digibox scart output to component for my SP4805
    all I can say is....wish I'd done it 6 months ago. :clap:
    no picture shimmer, higher contrast, better colours, more solid pic.....well, pretty much everything better really.
    And I thought It looked 'OK' before :rolleyes:
    thanks to Gary666 for his recent recommendation to get a converter....that was the clincher to me making the decision.
  2. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,035
    Harrow, NW London
    +599
    im getting a Sky+ box on saturday (new installation), i thought they might have component outputs on? or is yours the normal sky box and it only has scart?.....i'm not too worried if its scart, i should be able to get scart-svideo into my amp, then upconvert to component in the amp (Denon 3803), hopefully i will have nice picture from the off on my PJ.....lol
    glad u got yours sorted tho, nothing worse than not getting what you paid for...lol
  3. Kramer
    Kramer
    No component on Sky+ either, just scart RGB & s-video.
    Upconverting from s-video to component may make switching/cabling easier but won't be any better, PQ wise.
    Hence the RGB - component converter :) .
    :smoke:
  4. Geordie Bry
    Geordie Bry
    Jun 27, 2004
    1,035
    +59
    hi there i have a sp7205 sky + is connected with a js technology rgb to component converter picture is superb a lot better than s video
  5. Supersonic
    Supersonic
    Jan 5, 2005
    1,032
    Surrey
    +142
    ...so what are these convertors doing that 'up' conversion in an AV amp doesn't do?
    (Am interested as I have an NTL box, the pic signal of which gets to my projector via my Sony RDR-HX510 component out. I was a bit disappointed with the pic but found out that the component out on the Sony is 'interlaced only' with video material. I also have a Denon 2805 which would up-convert to component).
  6. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    They're converting a signal of similar grade (RGBS) to comonent (YUV) whereas almost all amps (except the very highest grade taking in digital eg. SDI or HDMI) will simply upconvert the S-Video or Composite input to Component, which will never be as good quality as a conversion from RGB to YUV.
  7. Supersonic
    Supersonic
    Jan 5, 2005
    1,032
    Surrey
    +142
    Makes me wonder what my RDR-HX510 does in passing the RGB signal to the component out. Sounds like even if I bought a convertor, it wouldn't add anything to the picture quality that I'm not already getting.
  8. mavice
    mavice
    Dec 8, 2004
    399
    Midlands UK
    +16
    just to clarify and hopefully answer any questions above
    I have connected Panasonic Sky (non +) box scart (RGB) output to the APTUS 1 converter which converts to Component YUV. (red green blue phono)
    This then goes into Denon AV amp 3805 which switches to my PJ, still in component YUV
    the amp also switches composite (yellow phono) and svideo but these are inferior quality, even after the amp as up converted to component before the 10m run to the PJ.
    RGB and component seem to be similar (best ) quality and so by converting the SKY scart RGB output to component wrings the max video quality out the sky box possible. Previously it was connected via composite (achieved with an argos adapter which plugs into the sky box scart and gives svideo and composite (yellow phono) output then into the amp which up converted to component.
    composite did seem to give best pic for me (better than svideo which had terrible shimmer - but I sdid have a pretty crap cable) but composite still had low contrast, slight blur, and shimmer on yellow objects. - not obvious until I got the converter :smashin:
    so, in short, for best pic quality from any sky box to PJ, use the rgb scart output and either
    1. connect through a converter in component YUV. - hi spec amps will switch this too. - My Denon 3805 does :thumbsup:
    2. not sure about this but you should be able to connect direct in RGB (no converter required) if your PJ accepts RGB which most do, but you will require a cable to change the SCART to whatever RGB input your PJ uses - normally VGA D-type plug PC input.
    I am not sure that my amp would switch an RGB signal so I did not go this route. :rolleyes:
    hope that helps......clear as MMUD
    oh...the keene converter cost about £80 delivered and came next day...compared to the JS units which are £120 ish - thats why I went for the Keene - the pic quaility seems very good and I am happy with it at the mo..
  9. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    We've designed the converters using discrete parts because we found we could get better performance, and therefore better picture quality, than what was available with integrated solutions. It is a more complex process, but does have it's rewards.
    Component and RGB are very similar in picture terms, but when you're converting you've got to ensure that you've got sufficient bandwidth to keep picture detail. That's where our design excels.
    All the best,
    Dr John Sim.
  10. guido
    guido
    Jan 13, 2005
    371
    Staines
    +5
    Just bought one of these too... was in Sevenoaks and they had one on a plasma dishing up Sky.. its the end of the month so thought what the heck and bought one. Have had quick go on Freeview box and seems pretty good on my SP4805... need to redo the cals though and save under different user setting... but looks good so far!
    The good thing about the Keene box is that it has an Audio out socket as well. The QED one does not and my Freeview box has no separate audio out, so the Keene one it was.
    Seveoaks also had the new Quad small speaker set... was tempted for a demo... but escaped with wallet intact :eek: ;)
  11. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    You're making the right move by using the correct signals, but if you want the best then you've got to buy the best converter. We've had other customers using the CYP (which QED rebrand) and it doesn't give as clear of as detailed picture as my design. That's the real difference with my products, I'm a A/V user myself so know what's important - picture quality.
    All the best,
    Dr John Sim.
  12. Jeffers01
    Jeffers01
    May 2, 2003
    375
    OXON
    +33
    You can buy a lead with RGB scart one end and component the other, ie converting without the need for an £80 box. As this is a huge cost saving I presume PQ is not as good?? I was going to try this for my sky+ box to PJ. Any comments?
  13. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Erm, no. If you're going to use component video (YUV / YPbPr), you need to converter the SCART output (RGB - Red, Green, Blue). It's not a simple case of changing just the connectors, it's a case that you need to change the video signals. To do that, correctly, you need to be very careful. And that's where my designs work best - converting but keeping picture detail.
    Many projectors may not take RGB so you need to convert to component, or even to S-Video. Even when a screen can take RGB, it may not be the best input for that particular screen. You may find that converting to component gives a better picture than RGB, as you find with Hitachi screens.
    But sometimes you don't need to convert at all. RGB via SCART on a Panasonic screen isn't too great, but put it via the VGA socket using one of my other products and it really does bring the screen to life.
    So, get the right signal for your screen.
    All the best,
    Dr John Sim.
  14. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Hi Symanski.
    A sort of related question.
    I tend to get a fair bit of DC offset from the RGB scart output on the SKY+ box which is very noticable on my projector picture, I wonder if converting from RGB Scart to Y Pb Pr using one of your excellent products might be just the thing instead of playig with handfuls of diodes or caps in the Scart plug?
    Curious and very interested in your answer.
  15. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    On the final output the DC is removed in the converter, using high value capacitors. The actual conversion process is very accurate, and has a wide bandwidth to maintain picture quality before it's passed to this output section. The problem with adding capacitors just to the SCART output, as your thinking of trying, would be that they'd have to be very large. If you put in the same value as is typical for a video output, you'd actually be halfing the value of the output, which could cause the picture to jump. Diodes wouldn't really help here either.
    So yes, it would effectively reset the DC levels for you.
    As a side note, some systems are using low value capacitors which means the picture varies quickly about zero, too quickly for the display. Cost cutting which means that you can lose picture. We prefer to use larger capacitors for this reason.
    All the best,
    Dr John Sim.
  16. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    Ahhh...it's always best to keep the signal in its original form...if the projector can take 15kHz scan rate at it's D-SUB VGA port like most Hitachis seem to do, it's just a simple matter of getting a properly wired SCART-VGA cable...PJ's specs should list the scan rates that are accepted...
  17. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Note necessarily always the case. It's best to use the signal that your screen works best with, and if you need to convert then pick the best converter.
    All the best,
    Dr John Sim.
  18. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Ta.
    "Just what the doctor ordered":D
    For info 220uF 10V caps or 1N4148 diodes (as many as needed) and a lot of trial and error can get a result (and a lot of cursing/burnt fingers etc....). Now off to find my order pad....
  19. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    Heres the crunch question....
    Does the JS converter produce a better picture than the Keene one at £40 more cost?
    Anim
  20. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Our converter is considered to be the best on the market. I designed the converter using discrete components as this allowed for a higher bandwidth than the available single chip converters. A larger bandwidth allows us to keep the picture detail through the converter, and this translates to a better picture quality through our converter than those based up on those band-limited chips.
    All the best,
    Dr John Sim.
  21. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    Sounds good to me John. So am I right assuming the Keene converter is a single chip version then?
    Anim
  22. guido
    guido
    Jan 13, 2005
    371
    Staines
    +5
    Keene is £80 whereas JS is £145 on their website... afraid that was just too steep for me... maybe if I was using it all the time.. but my excursions to Freeview on PJ won't be very often.
  23. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    We're the only ones who recognised the need to use discrete components to get that larger bandwidth. The single chips solutions looked to give a comparible bandwidth to the S-Video, but component should be better than S-Video. Therefore, my design has a larger bandwidth to give more detail and better colour fields.
    All the best,
    Dr John Sim.
