badbob
I'm looking into building a HTPC to replace my two DVD players, to connect upto the LCD TV via DVI. It'll be used to playback DVD's, Mpeg-IV video files,OGG & MP3 files, and to scale video to the LCD's native pixel mapping. Digital audio will be sent to the HT processor for DPL/DD/DTS processing. It has to be silent as possible.
So a quick tally up of prices/parts..
Aspire X-QPACK Black/Blue Aluminium Micro ATX Case - With 420W PSU
MSI RS482M4-ILD SKT939 Radeon XPRESS 200 (RS482) Chipset Dual DDR400 PCI-E MATX
AMD (venice) Athlon 64 3000 + OEM 512Kb Cache Skt 939pin
CRUCIAL 1GB DDR PC3200 400MHz 184-PIN UNBUFF 128MX64 Memory Modules
Sapphire Radeon X1300 256mb 128bit DDR2 PCI-E VGA/DVI/TV-out Lite Retail
Zalman (CNPS7700-ALCU ) 120mm Super Flower Cooler (Al/Cu)
Western Digital WD2000JB SE 200GB 7200RPM ATA/100 8MB Cache
Microsoft OEM Media Center Remote Control Inc Reciever
Hercules Fortissimo IV High Def 7.1 Surround Sound PCI Soundcard
LG GDR-8164BL 16x52 DVD-ROM Internal IDE (Black) - OEM
£510 total inclusive of VAT. Any thoughts on this machine? I will check up if the Zalman flower fits. Any parts you would change? What about the video card? I know I have to install FFDSHOW, but is that enough? When I play a video file two FFDSHOW icons pop up in my taskbar, so I presume it's working- or do you have to fiddle with settings? I will use Power DVD 6.
I have a Home Theatre Master MX-700 remote. Is it possible to buy a micro ATX case with a built-in IR receiver onto the case front panel rather than having a external dongle? And connect upto a IR header port on the mobo to. I don't need the physical remote, just the IR codes in CCF or MXD/MXF format. OS will be Windows MC, stripped down of excess stuff with XP Lite/disabled services and using it's own front end.
I'll be having another PC, but that'll be a gaming PC. Connect DVI -> HDMI
