Application for determining projector and screen sizes?
Discussion in 'Projectors, Screens & Video Processors' started by deefadog, Jun 16, 2009.
  1. deefadog
    deefadog
    Aug 4, 2005
    2,121
    +92
    Hi all, i am after an application (mac if possible) but pc will do, that once hooked up to a projector via a laptop will display different ratio's - 4:3, 16:9, 21:9 ect.
    i am sure i saw something on here that produced a boarder with a circle, to see if any stretching was going on.
    The background is I am setting up a few meeting across Europe and would like this app so i can test what the limitation are with some of the auditoriums we will be using as the translation can sometimes be tricky with technical specs.
    Cheers for any help!
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,525
    Kent
    +830
    Get yourself a test pattern disc such as DVE or I can't remember the name of Spears' new one. It will have this basic pattern, and many many more for testing the abilities of your display.
  3. Neil Davidson
    Neil Davidson
    Well-known Member AVForums Sponsor
    May 10, 2004
    2,064
    116
    Glasgow
    +504
    Or try
    Displaymate
    or
    CalMAN Test Pattern Generator
    Both of which should do what you want. The CalMAN generator is free so I would try that first!
  4. IanW
    IanW
    Feb 28, 2001
    1,658
    Wiltshire
    +167
    A simple version of this is included in the THX optimiser found on many DVDs.
    Ian.
  5. deefadog
    deefadog
    Aug 4, 2005
    2,121
    +92
    Thanks all!
