Sebastalona
Outstanding Member
S4 owners, is there a way to turn off the ambient light sensor? Not loving how dim it is when I raise wrist and have to tap to get full brightness.
Did you try it on with the sports band or the nylon band?Just realised the one i tried on was the silver Nike one. Very nice looking watch.
It was the white sports band, that’s why I thought the watch was white.Did you try it on with the sports band or the nylon band?
That looks really nice. I’d quite fancy that if I didn’t like the style of strap without buckles.Bought this to go with my Space Black S4;
https://www.amazon.co.uk/gp/product/B01MZ947LC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I wanted a good quality leather strap and saw these on You Tube. If not good quality they're going back!That looks really nice. I’d quite fancy that if I didn’t like the style of strap without buckles.
That’s what I love about Amazon lol.I wanted a good quality leather strap and saw these on You Tube. If not good quality they're going back!
If youve gone from the clock screen into a message, pressing Digital Crown takes you back to your last screen - which would be the clock face, if this is what your referring to? Give it a try see if that helpsOk, i have a question. I’m normally good with this sort of thing but as my old watch was so old and didn’t run OS5 this is all a bit new to me.
Facebook and Youtube on the S4. What are the options? Ive got messenger running ok but wondering if the other two will work, or if there are work arounds that don’t involve me opening links in messenger.
Oh, and one more bonus question. I can open and read messages ok, but is there a quick, direct way of going back to the home/clock screen? I can go back out but its a two step process.
Thanks for any help.
Thanks, that’s what I thought would happen but its not. For example. I go from the clock screen to messages, then click on the message. Going back takes me to the message list, then one more press takes me back to the clock.If youve gone from the clock screen into a message, pressing Digital Crown takes you back to your last screen - which would be the clock face, if this is what your referring to? Give it a try see if that helps
Got the Nomad strap today. High quality but a little stiff. Should soften up. Here’s some pics.
The Nike versions also have Nike specific watch facesIs there difference between Apple Nike watch & normal Apple watch? Is the difference just the strap or is the spec different too?
