Answered Apple TV no sound
Discussion in 'Video Streaming Boxes & Services' started by Pearfish01, Jun 22, 2015.
  1. Pearfish01
    Pearfish01
    Nov 9, 2007
    306
    Bushey
    +8
    Searched everywhere guys can't find the answer. Connected the Apple TV Gen 3 to my Denon 2310 receiver via HDMI got the picture working but no sound. Should I try an optical cable for the audio? I can't remember having a problem when I last used it but its been in storage for 2 year and now updated with later firmware.
    Any suggestions guys?
  2. Best Answer:
    Post #2 by Warpaint, Jun 28, 2015 (1 points)
  3. Warpaint
    Warpaint
    Jul 26, 2003
    605
    28
    Edinburgh
    +62
    Best Answer
    Try the Apple in a different hdmi input on the Denon. Possibly use one that you know is working with another device. Maybe the Denon has the audio assigned to optical or coax on the input you plugged the Apple into.
    Failing that, a reset of the Apple TV might help. ' settings- general- reset'
    Or possibly a full restore to factory settings in the same menu.
  4. Pearfish01
    Pearfish01
    Nov 9, 2007
    306
    Bushey
    +8
    Worked a treat after full restore to factory settings cheers.
