Bat-man
Thanks so much for the heads up. Just arrived.I have a white silicon case on my remote which is non symmetrical so I can see at a glance which way round it is. Also stops it being so slippy.
Had it a lot but a restart (unplugging and a switching back on cleared it).Anyone have issues with the pause button not working in the Apple app? Doesn't work with my harmony or the standard remote.
Thank you, a simple restarted did it.Had it a lot but a restart (unplugging and a switching back on cleared it).
Hello - do any other users of Infuse find that lossless HD movie tracks don’t sound quite right?
Im finding that movies with Dolby True HD often sound muffled playing via Infuse.
I suspect it may be that my (Denon) AVR’s processing sounds different applied to LPCM vs untouched bitsreamed Dolby (and DTS) audio. Which of course wouldn’t be Infuses fault. I use two post-processing features - a volume levelling feature and upmixing (to my Atmos heights).
Just curious if anyone else finds this?
Hi mate,
something you can try, just for testing purposes. force the atv to output as DD, I appreciate the quality will be worse but as your denon will be receiving the audio in the DD container you can see if there is any difference in how your amp handles it versus PCM
I find that the best sound I hear from my Apple TV is from infuse playing lossless audio tracks. I have no issues whatsoever. I’m using a Yamaha amp.
Same. Sound is much better through infuse on my Yamaha app. The Apple TV one seems to be all over the place for me since the last update sound wise.I find that the best sound I hear from my Apple TV is from infuse playing lossless audio tracks. I have no issues whatsoever. I’m using a Yamaha amp.
Yeah I use Dolby surround upmixing. Might just be down to how different amps handle it.
I always leave my amp in 'straight' mode so it just takes the channels that come out of the ATV unaltered. I only switch on processing for stereo or mono material to throw it round all my speakers. All movies sound great that way. I found it I upmixed 5.1 to 7.2.1 it often sounded worse than untouched.
No problems with iPlayer, but Netflix is a blank screen, but can get it via TV's apps.Is BBC iPlayer working for anyone else?
All I’m getting is Something went wrong Please try again later.
Edit: never mind, deleted the app, downloaded again and now seems to be working as it should.
Netflix is working fine for me.No problems with iPlayer, but Netflix is a blank screen, but can get it via TV's apps.
hi guys, did anyone faced a problem that Apple TV 4k can not output dolby atmos through a Pioneer receiver (dolby atmos able)?the receiver model is Sc-lx 58
I also have a projector - a jvc DIL-A Rs 49. it has 4k shift and it can pass 4k signal up to 60fps. I have no issue with the picture, which is actually very good, better than 1080p. my problem is that dolby atmos from Apple TV 4k can not be recognized by my Pioneer SC-LX 58. do you happen to know if other forum members had this issue.Hi
My ATV 4K plays fine through my pioneer amp in Dolby atmos. But it’s going SDR to my projector in case that makes a difference?
