Apple TV 3rd gen i cant see itunes
ADAMFOULKES
I I have bought the above but I am having no luck with apple tv seeing my pc via iTunes to steam music. I have done everything I am supposed to but home sharing is not working. I have a massive library in iTunes. Could that be the problem?
next010
If the ATV cant see iTunes then it usually is a problem with bonjour, re-install iTunes on your PC and hopefully that will correct the problem.
If some rare cases bonjour has problems with homeplugs if they are being used, check that your routers firmware is up to date as well, also check that multi-cast is enabled on the router.
