Craig McArthur
Hi all
I'm looking for a product or someone who can be commissioned to make the following:
A small (as thin as possible, matchbox size would be perfect) box I can position under my desk with the following connections: one 3.5mm out going to an iMac. One out going to USB if power is required. Two 3.5mm inputs. There would be a button or switch to go from one input to another. The box would need to support Apple Headphone media connections (volume, click control + mic) and pass it along to the iMac. Also, the audio quality coming from the iMac cannot be compromised.
If there's no hope for the above then my 'make-shift' option will be to run a 3.5mm extension cable that supports Mac iPhone media controls under the desk and swap the connections myself, so if anyone could also suggest iPhone headphone supporting extension cables (the ones with 4 metal bits on the jack?) I'd also appreciate that.
Many thanks in advance for time and help
Craig
Craig
