Apple Music lossless audio is now on Android. So seeing as the Android OS restricts you from getting hires lossless or 24bit 192khz how do you listen to it on Android? Does the app circumvent this android OS restrictions like the tidal app or is just snake oil? Or is it a case of using an external DAC such as the audio quest dragon fly black but then does the OS stop this?
Not an Apple user, but anyone who is anyone uses the USB Audio Player Pro app UAPP on their Android either with ir without an external DAC. This bypasses the internal Android OS limitation. Many higher end Android phones have better DACs than the stock model, and any external DACs do. . The UAPP comes in two parts, ..a driver which snaffles the audio , and is used either internally or externally and a conventional music player app. . Sometime I like to think I am somebody.
