Apple IPOD with ability to receive radio?
Discussion in 'Headphones, Earphones & Portable Music' started by NPA, Mar 19, 2006.
Tags:
  1. NPA
    NPA
    Sep 26, 2005
    74
    a friend of mine told me about somebody who has done something to his Apple IPOD to allow him to receive FM through the IPOD. Anybody know if this is possible & if so how/cost etc?
  2. Tides2002
    Tides2002
    Jul 5, 2002
    141
    +12
    The latest generation iPod’s can be teamed up with a new wired remote control that also has a built in analogue radio receiver.
  3. NPA
    NPA
    Sep 26, 2005
    74
    Thanks. How is this done? What would i need to buy?
  4. Juliesinar
    Juliesinar
    Oct 28, 2003
    905
    +64
    Apple Ipod Radio Remote £35
    "Listen to FM radio on your iPod and control everything with a convenient wired remote. You also get a set of earphones with a shorter cable that’s a perfect fit for the remote. Compatible with iPod nano and iPod with video"
    A friend bought one and was a bit dissapointed as it seems to need a stong signal to get decent sound, might be OK if you are in a stong signal area though.
