Quantcast
APPLE 6S6?
carp2222
Dont know where else to ask maybe someone else had this problem
My I phone 6S6 when charging screen shows notification saying APPLE does not recognize this application
THANK YOU
TIMMY
JayCee
There is no iPhone 6S6
You've obviously got some program running in the background, have you checked?
JayCee
can you put the apple sim card from apple phone into an:) apple i pad
Only if the iPad is a cellular model.
You didn't answer my question...have you looked to see if any apps are running on your iPhone?
JayCee
With the notification on screen does it disappear if you unplug the charging cable?
bransoj
Are you sure its not this message you are seeing?
If so then its because it doesnt like the cable you are using normally because its a cheap 3rd party one that doesnt have the chip in it like a made for iphone cable.
BM08
As above, just try changing the cable/using a different one.
It’s a message that all iPhone/iPad users would have seen at some point
Similar threads
Trending threads
