Can somebody clarify i have this correct...
Getting my new OLED TV tomorrow and will using with a new unused Apple 4K TV box which will feed through to my Sonos Playbar. I will be also using the inbuilt tuner for normal TV.
Regarding the set up, I have checked and can see that Apple 4K doesn't support 5:1 optical audio so I am buying a splitter - HDMI Splitter 1 in2 out 4K 60Hz 4:4:4 HDR Dolby Vision Dolby Atmos SPDIF 5.1CH Breakout - HDMI Scaler 4K 1080P Sync,Firmware Upgrade HDMI 2.0 Splitter 1 in 2 Out 18Gbps HDCP2.2, CEC, Slim Case SP12
I have HDMI 2.0 cables for this as well.
So the set up will look like this: Input Apple TV & Playbar (with 2x play 1's as rear speakers) via optical to splitter then HDMI connection from splitter to TV.
Will that work ok and is it the best method?
Originally I was just going to attach the Apple tv straight in to the tv along with the playbar via the TV inbuilt optical connection but am thinking as apple TV doesn't support optical audio it will only output in generic stereo... unless the TV can convert the signal from apple tv?
I am a bit confused!
