Quantcast
Apple 4K TV for dummies
sugarmichael
I am approaching this with close to zero understanding of media streaming and up until now solely rely on a TV a Sky box and a DVD player. However I am in the process of upgrading my TV and in doing so evaluating what else I need to upgrade i.e. Sky Q, 4k Blu ray and sound bar etc.
Which leads me onto Apple 4K TV. I apologise in advance for this question but why, for someone without previous investment in the Apple infrastructure i.e. no large catalogue of Apple content, why would I need Apple 4K TV when my new TV would have 'smart' capabilities. Is there a picture advantage, a cost advantage or any other reason?
My objective is to increase the quality of programming that I am watching (I don't mean University Challenge rather than Coronation Street!), increased quality as in HDR, 4K and Dolby Atmos etc.
Thank you for any replies.
Fred Smith
Your new TV will have limited smart capabilities and will not support all apps.
I have a smart TV and a Apple TV 4K, Chromecast Ultra, Roku Streaming Stick + and a UHD blu-ray player to cover most current UHD sources and other content and the TV is also 4K capable via it's built in satellite tuner but not for Sky so I did for a while have a Sky Q UHD box but no longer.
You need to see / decide which apps etc you want to use and then purchase one or more devices which support these apps etc if the TV does not support them.
sugarmichael
Thank you Fred.
The Sony XF9005 Android platform comes with Netflix, Amazon and Chromecast, plus TV catchup channels, so I would envisage that this will cover the majority of what I would need.
MarkE19
Cheap 4K movies is another reason for the ATV. You can often pick up cheap HD films for a couple of quid (older movies normally this cheap) and if available now or at a later date in 4K you get it upgraded to 4K for free once available.
Even new release films are mostly far cheaper than an UHD disc, the quality is close but not quite as good though.
Mark.
ristac
Exactly this below:
Mark.
I recently purchased a new 55" C8 and I naturally thought I wanted to watch the absolute best quality I could so I splashed out another near £200 on a 4K blu ray player. I then found a 4K movie for £25 and my first thought was this better be good as £25 a disk is a bit steep. Yes it was fantastic I can't deny that but I thought I would give the Apple 4K TV a go.
I am now watching 4K movies on Apple for under half the price of a 4K disk, yes the quality is ever so slightly less on Apple over a 4K blu ray but negligible. If you want to get into the world of UV codes and Movies now it is even cheaper.
I've got Venom, House With Clock In Walls and 12 Strong all ready to watch and all three cost me under £20.00 total doing the UV code route.
jwsg
I decided to go ATV 4K rather than UHD blu-ray with a C8.
Yes there are some disadvantages - the lossless audio on disk cant be beaten; and I'm missing having two HDMI as I route it via my Denon with the TV HDMI set to PC so I'm losing some video-friendly settings - although when the film's in DV its fine
But I've been able to get a stack of 4K films for just £3-5 - as I've most on blu-ray I just dont want another shelf of disks.
mikeybabes2
How do you mean the UV code route.
I thought UV was ultraviolet which is having all sorts of issues with providers. I had a load of movies through flixster and I understand they are no longer participating......
Thanks.
nero0410
@jwsg
Can't comment on 4K, but I use this to send hdmi to both tv and projector at the same time from my nVidia Shield (Used to use it with a htpc before the shield):
https://www.amazon.co.uk/gp/product/B00IE3T2EU/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Very handy piece of kit and well built :)
Over by there
My choice was the streaming rate for 4k. It is mid to high 20's and very good, on par with BT Sport 4k quality and ahead of Netflix (no matter the platform for basic 4K for me), they top out at 15mb/s. After I bought it Apple introduced frame rate matching etc. which was an improvement.
About frame rate and dynamic range matching on Apple TV
Not sure my LG is updated past being functional anymore.
I have a disk player for the films I want the full visual experience.
Cheat Charts App (free at the moment) points the way for discounted films on iTunes. Many 4k. Some get bumped up and on the odd occasion they lose 4k. I can only do HDR tops so no idea what Dolby Vision looks like on ATV.
4K can get pulled on iTunes and you are left with the HD version. Films can get pulled I am told, the T+C will have the info. Encourage you to read them.
Apps wise you can access various catch up. iPlayer is OK but will not do the BBC UHD tests. I am not sure it ever will. Commercial TV apps are what you would expect. Apps are supported by BBC or ITV etc. so any differences are down the to. BBC or ITV etc. not Apple as I understand it?
There are a few games worth a go but in the main it is not a gaming machine.
HeweyBoy101
I have the Sony 49XF9005 with Apple TV 4K.
The ATV does pretty much everything better than the built in apps on the TV, so much so that I pretty much use it all the time. The Android system on the TV is pretty sluggish mind you.
I use ATV for:
iTunes movies in 4k / HDR / Dolby Vision / Atmos - often pick up films for a fiver when on promotion.
The TV App - brings together all streaming services into one single app and works very well indeed.
Music streaming - if I want to listen to Tidal or Apple Music I just airplay via the ATV.
Local streaming - I have all my blu-rays ripped to mkv and use the Infuse App Pro to stream. This is probably the best app on Apple TV for me as it is 100 times better than Plex (which I used for many years) and (best of all) I can now stream direct (including HD audio formats). I absolutely love it!
Finally, both Netflix and Amazon apps work flawlessly on my ATV and both include the required 5.1 / Dolby Vision / Dolby Atmos / HDR features available on certain series.
I did however have to update the firmware on just about every one of my devices to get some of the features to work (Dolby Vision especially)!
Overall I am immensely happy with the ATV 4k - it’s now a “one stop shop” for just about everything I watch (or listen to) - I have hardly used my disc player in the past 2 months!
Marshall Mike
I use ATV for:
I’m getting the ATV 4K for Christmas and was wondering about streaming Blu-Rays from my NAS. I currently use Kodi on my Xbox which works very well, certainly a lot better than Plex! I understand the options are Infuse, Plex and MRMC on the ATV? You mention Infuse plays back in HD Audio but I thought ATV was DD only? Hoping I’m wrong!
HeweyBoy101
I previously used Kodi (on Amazon Fire TV), and Plex (on various platforms), and then discovered Infuse only a couple of weeks back - it's in a different league!
The ATV itself cannot pass HD audio, but the Infuse App works (somehow) by decoding the audio and then passing this as uncompressed PCM. Have a look at the web link below which explains everything.
Audio Options (tvOS)
I was sceptical, but as soon as I head the soundtrack on Jurassic Park Fallen Kingdom I realised it was definitely the full HD audio coming through (the amp just says PCM 5.1 but you can tell straight away compared to Plex which transcodes everything).
Also, the set up was very intuitive and was able to scan my entire media library (700 titles) via an SMB share, in less than 30 minutes, with correct artwork and everything. Hardly any errors. Plex would have taken a couple of days! Artwork can be changed if required by adding a jpeg to the relevant movie folder.
I could go on - there are other ways to customise Infuse but probably best to have a read of the various user guides on the Firecore website.
Scarty16 above mentioned the Nvidia Shield. I have not tried that but understand it's superb. Personally, I like the ATV as it just works for me and I am a bit of an Apple fan. NVidia might well be a better option if you are not such a fan of iTunes and don't need or want to buy / rent 4K titles from Apple.
Marshall Mike
Cool, really looking forward to trying Infuse out! How much is it?
HeweyBoy101
For the Pro version I had it on a free trial and when I realised how good it was I decided to subscribe - it's £8.99 per year on an iTunes subscription.
A bit more info copied below as regards the HD Audio ...
Infuse does support DTS-HD MA and TrueHD, and the full lossless audio will be sent to your receiver as LPCM.
The decoding process itself is standardized between all Dolby/DTS certified products (Infuse is certified and licensed for both) so in the end there is no difference whether this decoding is done by Infuse or your receiver. A bit more info on this can be found here. Audio Options (tvOS)
The only real caveat is Infuse is not able to support Atmos or DTS:X due to limitations in tvOS, but this is something we are encouraging Apple to change. A few more details can be found here. Help get Dolby Atmos on Apple TV | Firecore
Marshall Mike
Awesome, I don’t have an Atmos setup so plain old 5.1 lossless is good enough for me :) And that £8.99 subscription is still a lot cheaper than Plex.
Marshall Mike
Bah, I just realised I have to hook the ATV straight to my tv as I have an older AVR. That means passing the audio from tv to receiver via toslink so no lossless audio for now.
HeweyBoy101
That’s a shame - I had the same issue before with my older AVR
Over by there
Same problem here but address it when I change the amp, I can easily live with it all things considered for my smallish room.
bobbybuilder59
Dont forget the Nvidia Shield "the daddy"!
I had a Nvidia shield before ATV but waited and waited for frame rate matching to be implemented but it never arrived. I only wish the ATV would be as open as Android, I really hate Apple eco system, I have nothing else Apple in our house and would never spend my money on a iPhone. But must admit the APV is probably the best media streamer available for picture quality.
-gonzo-
Thanks.
He means by setting up a US iTunes account which via a couple of other services you can get US Ultraviolet codes to port to US iTunes, as well as that you can also have most of your Ultraviolet content from Flixster port to the US iTunes account too.
Trending threads
Latest News
Samsung Onyx cinema LED screen opens in Australia
  • By Andy Bassett
  • Published
Disney CEO Bob Iger steps down
  • By Andy Bassett
  • Published
Quantum Dot development could mean cheaper displays
  • By Andy Bassett
  • Published
Netflix launches daily top ten rankings
  • By Andy Bassett
  • Published
OLED TV sales exceed one million in Q4 2019
  • By Andy Bassett
  • Published
