Apologies another E85 RGB Sky+ Question
Discussion in 'Blu-ray & DVD Players & Recorders' started by lloydo, Nov 2, 2004.
  1. lloydo
    lloydo
    Mar 1, 2002
    75
    Letchworth
    I've searched the forum and tried the normal solutions (making sure SKY button pressed on remote not TV etc.) but I still cannot get a RGB picture on my E85.
    I've got Sky+ > scart > AV2 on E85 outputting RGB
    E85 is set for RGB on AV2
    E85 > component out with S-Video > Panasonic 5 series Plasma (through tuner box)
    When AV2 is set for video I get a crappy picture but when I set it to RGB I get a blank screen, any ideas?
    DVD playback on Prog Scan is good though....
    Thanks in advance.
  2. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    I take it you have a fully wired scart?
  3. lloydo
    lloydo
    Mar 1, 2002
    75
    Letchworth
    Yep, it's a brand new QED one, would I see any signal if there is something wrong with it i.e. plain video.
  4. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    Yes its unlikely all leads would be broken so you'd get some sort of distorted picture.
    I take it your plasma only accepts component. Do you have another TV you can connect to temporarily? If so then I would suggest connecting Sky to TV direct and confirming that the Sky is outputting RGB, then putting the E85 in the way (using 2 scarts) and checking whether you get RGB pass thru ok (E85 in standby). Then turn on the E85 set it to output RGB and see if this works ok. This should help you pin down where the problem is.
  5. lloydo
    lloydo
    Mar 1, 2002
    75
    Letchworth
    I've got Sky+ and the Plasma connected directly by scart and RGB set on the Sky+ box so it looks like that end is OK. I'm using the second scart from the Sky+ to the E85, perhaps I'll try it with output from the scart which goes to the TV, see if there is a problem with the second scart, I'll be surprised as it is outputing normal video.
    Cheers for your help Bobcar
  6. alicat
    alicat
    Oct 13, 2004
    92
    Sky+ only outputs RGB to the TV SCART. The video SCART is video composite only. You have to swap the two SCARTs over
  7. lloydo
    lloydo
    Mar 1, 2002
    75
    Letchworth
    Ahhh right, I'll try that, so I will have to pass the Sky signal through the E85, save myself a cable then, might try to get my 50 quid back if it works, cheers alicat
  8. lloydo
    lloydo
    Mar 1, 2002
    75
    Letchworth
    Just a quick update, tried the pass through with component out and prog scan, picture quality degraded, the no prog scan, better but still not quite right, then scart out, picture better again but still degraded slightly. Basically I don't want to live with the degradation in the Sky picture so looks like the E85 will be going back unfortunately. Cheers for your help.
