Apollo Hi-Fi Furniture
RS2
Any thoughts on Apollo hi-fi furniture? What about the build quality? I'm thinking about the metal Mezzo Soprano in the picture below. /RS2
Bonesy
I have apollo aria, and like it,
it is fairly cheap, more cost-effective because it is flexible (you buy what you need), and does take some time to put together.
looks good, is fairly weighty, and prefer it to bigger fixed systems.
not sure if the mezzo is also moduler
kenjolly
I have the 5 shelf Hi-Fi stand and my mate has both of the stands in your picture.
I'm very happy with mine - the guy is open to a bit of haggling (at the hi-fi shows anyway !). You can change the height of all the shelves by buying different sized columns. Glass is really thick so making it a bit heavy. You can even change the columns for a different colour (my mate seems to be interested in the "anitue gold" effect they do - silver for me though)
Definitely recommended.
Kenneth
dts_boy
i have the av one, its great! if its the av one your after i have 1 shelf spare and would be open to offers - i ordered 4 and whenit came to building the wife decided that 3 looke better and have one spare:mad:
