Apex A10 as height speakers
Discussion in 'Home Cinema Speakers' started by stewjoy, Mar 25, 2018.
  1. stewjoy
    stewjoy
    Nov 8, 2005
    1,159
    2
    2
    63
    +247
    As the title says, has anybody attempted this ?they are very heavy if so what size screws or fittings did you use. Any help appreciated.
  2. fayeanddavid
    fayeanddavid
    Sep 23, 2009
    5,521
    Bearsted Kent
    +1,923
    Just seen this:
    Wall mount or ceiling mount.
    The mounting bracket gives you loads of options, I had mine at max height wall mounted, angled down to the MLP, worked very well, use with confidence
  3. stewjoy
    stewjoy
    Nov 8, 2005
    1,159
    2
    2
    63
    +247
    Thanks, got someone coming Wednesday to fix them for me.
