Apart Mask 6 Garden Speakers - Best outdoor cables / Pioneer setup
Demiurgeuk
Hi Guys. Having a hottub installed in a 5 x 5m summerhouse. Will have a TV and SkyQ remote box inside. Looking to run a pair of speakers inside and a pair outside the summerhouse. Will be used for music mainly and watching the football, unlikely to be watching films etc.
I have an older Pioneer VSX-1016s in the loft in full working order. I was planing on using this connected to the TV / Sky and adding a Logitech bluetooth receiver for music streaminh from phone. Been reading though a few posts on here and am thinking of Monitor Audio Climate 60's inside and Apart Mask 6 speakers for outside (on the zone 2 outputs). Can someone suggest a suitable speaker cable. Also any advice on the above would be welcome. Thanks in advance.
DigitalDigger
When I did outdoor speakers, I put speaker wire inside hose pipe and sealed it. The connections were done inside a tupper wear box and silicone around the holes i drilled (speakers were rocks that had short non removable cables).
Worked just fine and with everything covered I just buried them
Demiurgeuk
Thanks. The external speakers will be mounted on the summerhouse so no long runs needed. Just not sure on the best cable to buy.
Podcast: The Best TVs of 2021, plus our favourite & memorable reviews of the year
