AOpen HTPC Media Center Server Case
Discussion in 'Computer Components' started by chrisfoster1971, Jan 16, 2008.
  1. chrisfoster1971
    chrisfoster1971
    Nov 20, 2006
    35
    +6
    Has anyone actually seen these beautys in existence as after a few weeks of looking I have plumped for this as my HTPC design. According to the spec sheet it is capable of hosting 7 interal disk and 1 5.25" drive, includes a PSU, VFD etc etc it seems all to good to be true.
    Product details as below
    AOpen Media Center Server 400/410 is designed to look like a conventional audio amplifier. The housing of the innovative product is designed with storage space for seven hard drives. The system is developed with the functions to receive video streams from multiple TV channels. A user can record video streams or TV programs of up to three different TV channels with built-in hard drives. The user can manage, edit, browse, or play back the recorded video streams or TV programs recorded in the system hard drives.
    The system also supports multiple screen output. A user can display the video output of different TV channels to separate video output devices such as a HDTV or plasma display. The Media Center Server 400/410 is ideal for a home with multiple TV sets.
    The system is built with vacuum fluorescent display (VFD) panel which shows the system playback status clearly. The remote control of the system enables users to operate the system conveniently.
    “Powered by the functions of high performance AOpen Media Center Server 400/410, the users can watch and record TV programs, play music CDs and MP3 music, play VCD and DVD movies,” explained Vincent Cho, VP and GM of Solution Products Business Unit. “As the most powerful digital home entertainment platform in the IT industry, the product is expected to start a digital home entertainment revolution in the near future,” Cho predicted.
    Features of Media Server 400
    * Built with large size VFD which shows system playback status clearly.
    * Designed with dual-channel TV tuner – the user can watch the program of a TV channel while recording the TV program of another TV broadcast station.
    * Supports Microsoft Windows XP Media Center Edition.
    * Supports 7.1-channel surround sound.
    * Supports Intel Pentium 4 2.8GHz 820 processor which is designed with dual core and Hyper-Threading technology.
    * Supports dual channel DDR II 533/667 MHz and expandable to 4 GB.
    * Provides PCI-Express x16 and PCI expansion slots.
    * Provides one ATA and six Serial ATA connectors.
    * Built-in 250 GB hard drive.
    * Built-in DVD Combo drive.
    * Built-in 10/100/1000 Mb LAN interface.
    * Full function remote control.
    * Provides S-Video, YPbPr, and D4 video output connectors.
    AOpen XC REC6 – AV system for sitting room, a combination of bed room AV system and conventional PC
    Although AOpen XC REC6 is also designed for providing digital home entertainment, the look-and-feel of XC REC6 is totally different from that of AOpen Media Center Server. The stylish and super slim XC REC6 is only 6.9 cm (2.72”) in height, making it ideal for sitting room.
    Despite its compact size, the product features the VFD panel and the push buttons which allow the user to operate the system easily and examine its operation status. Even though it is one of the slimmest desktop PCs in the world, the small size does not mean performance sacrifice. It supports nearly all important audio and video interfaces including S-Video, YPbPr, and D4 connectors for displaying video output to HDTVs or LCD screens.
    AOpen XC REC6 is designed to be driven by Intel Pentium M processors, which consume less electric power, generate less heat, and run quietly.
    EP915-M
    * The size of the product is only 8.9 liters – nearly the same as home electronic products.
    * Provides one 5.25” and one 3.5” drive bay.
    * Built with a stylish VFD panel to show operation status.
    * Supports multiple-channel audio outputs.
    * 275W power supply.
    * Dimensions: 69mm(H) x 300mm(L) x 430mm(W); 2.72” x 11.81” x 16.93”
    * Supports Intel Pentium M Dothan processors.
    * Supports Intel i915G and ICH6 chipsets.
    * Supports dual channel DDR II 400/533 MHz.
    * Provides ATAand Serial ATAconnectors.
    * Provides S-Video, YPbPr, D4 video output connectors.
    * Provides USB, IEEE1394, and HD Audio 7.1-channel sound.
    * Built-in 10/100/1000 Mb LAN connector.
    If anyone has seen it or know of something similar I would appreciate hearing from you:lease::lease::lease:
  2. Chuck_Norris
    Chuck_Norris
    Aug 23, 2006
    1,656
    peterborough
    +31
