Aol wireless connection
Discussion in 'Playstation Forums' started by delboy630, May 5, 2007.
  1. delboy630
    delboy630
    Apr 23, 2006
    54
    Just upgraded to wireles, my netgear router is wired to my computer, on the AOl disk supplied I conected my router after that I had the option to make my computer wireless then after that connect other wireles devices, both of which i declined. Tried to connect my lads PS3 but it does not pick up the SSID when you press scan. Should I have loaded the other two options?
    please advise.
    thx Alan
  2. bigkingy
    bigkingy
    Jan 23, 2006
    1,101
    Forest of Dean,England.
    +183
    You have to turn wireless on, the first option you declined. A wireless logo on front of router should light up green.
