AOC e2250swda - Brackets needed
Discussion in 'Home Cinema Buying & Building' started by mboora, Aug 4, 2013.
Thread Status:
Not open for further replies.
  1. mboora
    mboora
    Jul 17, 2013
    27
    Hi I have two AOC e2250swda monitors and I want to wall mount both side by side in my bedroom.
    Link to monitors
    What brackets do you recommend?
    Both monitors are used for my computer.
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    We have a range of mounts that are suitable for TVs and Monitors
    TV Mounts
  3. mboora
    mboora
    Jul 17, 2013
    27
    Thanks.
    How do I know if the mounts are compatible with my monitor?
  4. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    If the Monitor states it has a VESA mounting, this is a sign that it takes a standard mount as there is a standard for monitor and TV mounts.
  5. Andrew K
    Andrew K
    Oct 14, 2004
    3,392
    +608
    Your monitors have a 75x75 mount fitting.
    If you want to have swivel movement then this one will fit :
    Cinemax C4 LCD Swivel/Tilt Bracket - Quantum AV
  6. mboora
    mboora
    Jul 17, 2013
    27
    Sorry for the late reply.
    I'm confused...
    It says...
    Brand:Cinemax
    Colour:Silver
    Width:115
    Height:160
    Depth:114
    Weight:0.0
    So how does that fit under the 75x75 figure you quoted?
    Also 0.0 for weight, am I missing something?
    Any other suggestions, anyone?
  7. mboora
    mboora
    Jul 17, 2013
    27
Thread Status:
