Evokazz
- Joined
- Mar 28, 2008
- Messages
- 2,508
- Reaction score
- 979
- Points
- 871
After many days messing with my system trying to get a nice sound from it, and finally getting my replacement sub (not pictured - new one is QA7070Si but in same position). I decided to give Audyssey one last try (previous settings were not ear pleasing). Now not sure whats changed in Audyssey, but the system while not sounding perfect, sounds a lot better this time round. I can't hear the subwoofer hardly when watching movies etc, but I have also read a good setup the sub blends into all the sounds, is this right? Also wondering if Audyssey has set my sub too low? but if it's correct then I'm happy, the Crossover on the sub is set to AV, and the Level on the sub is at 55%
Here's the layout of the room, it's a fairly small room, measuring 4 meters x 4 meters.
As advised speakers all in correct positions, I have since taking these pictures put some Auralex Mopads under the center speaker, to tilt up upwards slightly.
Now here are the key settings Audyssey has given me, is there anything here you would change? So far all I have changed is the Dynamic Volume to Heavy, as it's really annoying when dialogue jumps up and down all over.
Distance on the sub seems a little high, but that's what Audyssey gave me, possibly countering the small room size?
Most of this seems ok to me (I'm no expert) but should the sub really be so low?
Many people have said to switch ALL crossovers to 80hz, but this is what Audyssey has given me, look ok? or changes needed?
I know every room is different, but given the 4x4 meter room size, and settings above, can anything be tweaked further? especially the sub and crossovers/levels etc
