david230 said:I will have a sony lcd rp at the end of the month and would like to connect my PC to it using dvi-hdmi. I know I need roughly 7metres of cable but is there anything to do with cable spec that I need to consider before I buy.
cheers for any help.![]()
This is not true a differance does happen, i have measured the impedance on cable-lead length, keep it as short as possible and go for the fastest cable within your budget.the longer the cable run the more the signal will degenerate, 7m is about 22ft; which is quite a long way, for such long lengths it would be wise to use a top quality cable...such as QED.
but on shorter lengths of say 1 to 2m, you can use any HDMI/DVI cable; because this no difference in signal loss between them all, well not that you'll notice![]()
