Anything compare with Pioneer 575?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dune, Aug 27, 2005.
  1. Dune
    Dune
    Feb 24, 2005
    267
    +16
    Just rang phoned the local Richer Sounds and they are out of stock :(
    Is there anything out there of a similar price (£100) that compares with the 575?
    I am not bithered about HDMI / DVI output at this price point, just the best prog scan picture you can get for the price.
    Oh, and I have gone off Toshiba as that was my current player that has just packed in :(
    Dave
  2. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    Pioneer 380 and 585, the 575 replacements ?
    check out on www.pioneer.co.uk for details
  3. jwramsay
    jwramsay
    Sep 7, 2004
    1,629
    West of Scotland
    +72
    Purchased one of these little beauts from RS Edinburgh yesterday, I've got to say, its A1+++++++++ for the dosh and I've had a few different players/recorders in my time.
  4. Jonmurgie
    Jonmurgie
    Jun 6, 2004
    806
    Cheltenham, Glos
    +44
  5. trevor g
    trevor g
    In short, NO, not for this price anyway. Ring round RS stores nearby to you, or order it from their on-line shop.
    You have to try and get one of them.
    All the best.
  6. PhillipJones
    PhillipJones
    HELLO!!!!! :oops: :suicide: :laugh: :( :mad: :smashin: :thumbsdow ;) :thumbsup: :) :rolleyes: :confused: :lesson: :hiya: :nono: :boring: :rolleyes:
  7. trevor g
    trevor g
    hello phil the pioneer 575 is an award winner and a what hifi favourite cracking
    picture and sound quality sacd/dvdaudio/ divx /pal progressive etc.
    if that helps regards trevor
  8. Sgt Steiner
    Sgt Steiner
    Aug 10, 2004
    107
    N.Ireland UK
    +3
    Not sure what spec is of Pio575 but a possible contender is Panasonic S49
    with Pal/NTSC Prog Scan 108mhz/12bit Vid and 192khz/24bit Audio decks.
    Great options for picture settings etc.
    I got one (multi-region) last week for £110 (online) to replace Phillips 3005 which was a great player for money but had some issues with 'flicker' which some say Pio 575 suffers from as well ? Panny image much more solid.
    Just another opinion/option :)
  9. trevor g
    trevor g
    hi sgt steiner the 575 does not suffer from this problem it is the newer 585
    according to what hifi in this months edition when pitted against some
    compaticion from other players in the test the 575 is an award winner 2004
    and a favourite of what hi fi ect
  10. Sgt Steiner
    Sgt Steiner
    Aug 10, 2004
    107
    N.Ireland UK
    +3
    I have never owned/seen a Pio575 so cant say first hand but my brother (Barso) did report finding some minor flickering he ended replacing it with with a Panny S97 (I dont need the Hdmi connection so went for S49).
    In all other respects he thought the Pio was top-notch and I think he still uses it as an Sacd/Music player ?
    I suspect at this price range (£90-£120) most players are comparable.
    Anyway just offering an altnerative :)
    Dont think the S49 has been reviewed in any mags as yet ?
  11. AlecF
    AlecF
    How about the Panasonic SC35?
  12. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    Buy a 565 form eBay for £40 and spend the other £60 on dvds instead!
