Anything better than a NadT743??
Discussion in 'AV Receivers & Amplifiers' started by Diving Bear, Jan 21, 2005.
  1. Diving Bear
    Diving Bear
    Having had to give up on my first choice of a Yamaha DSP AX750 becuase it simply won't fit on the only shelf available :mad: I ahve decided on the Nad T743. This has a depth of only 350 and allowing for stuff at the back will fit the space available. it has pretty good reviews in most places,just not outstanding. I am sorry it has a receiver which the Yamaha didn't, I have no use for an receiver as I listen to digital channels.
    Does anyone have any other ideas for an amp that is 'petite' in depth???
    Otherwise its the Nad
    Cheers :hiya:
  2. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    Perth, Western Australia (Originally Ireland)
    +226
    What about the Cambridge Audio 540R? I think the NAD is a pretty good unit though.
  3. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    How do you find your tannoy front ive got the same but not fitted yet there 6 ohms do theyv go loud or not being 6 ohms please ?. but puzzled what to put put on the rears dipole or some more R2 s or even R1 s what did you find worked best for music and films ??yes nad make fine stereo amps used to have one ,av amps would be musical me thinks from nad . :offtopic: :lease:
  4. Diving Bear
    Diving Bear
    I thought that they would be good with music, but its mostly films I want the sound system for.
    I was thinking of putting the Mordaunt Short Premiere Plus with these, or maybe the Wharfedale 9s? Any thoughts???
  5. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    +226
    The Tannoys were great - I recently changed them for Richter Floorstanders (an Oz brand). The new room was a problem so I needed speakers capable of going lower to avoid bass humps. But the Tannoys have served me well for a long time, and I do miss having them around!!!
