Anyone with JVC DR-DX7?
Discussion in 'Blu-ray & DVD Players & Recorders' started by EN, Nov 28, 2004.
  1. EN
    EN
    Jul 24, 2000
    267
    19
    Sofia, Bulgaria
    Is it possible to record from tuner in DV mode on HDD?
    In manual there is such mode only for copying from DV tape.
    p.62
    Dubbing From DV To HDD
    It is possible to perform automatic dubbing of all the recorded
    programmes of a cassette from the DV deck to the HDD deck
    using the “ENTIRE” dubbing.
    1 Load the Mini DV cassette you want to dub. Make sure its erase
    protection switch is set to “SAVE”.
    ● Set “DV AUDIO REC” to the appropriate mode. (_ pg. 76)
    2 Press DUBBING to access the Dubbing Menu screen.
    3 Press rtw e to select “DV ]HDD”, then press ENTER.
    4 Press w e to select “ENTIRE”, then press ENTER.
    5 Press rt to select “SELECT REC. MODE”, then press
    ENTER. Press rt to select the desired option (DV, XP, SP,
    LP, EP or FR), then press ENTER.
    6 Press rt to “SELECT SND. MODE”, then press ENTER.
    Press rt to select the desired option (SOUND1 or SOUND2),
    then press ENTER.
    7 Press t to select “CONFIRM”, then press ENTER. The
    confirmation screen appears.
    8 Press w e to select “EXECUTE”, then press ENTER for
    confirmation.
    p38
    Recording Mode
    MPEG2 format is used as recording format. As a guide for picture
    quality, the “bps” unit is used to represent how much data can be
    recorded per second. The larger this value is, the better the picture
    quality becomes but more capacity is required for the recording.
    Select XP or SP for programmes where quick movement occurs,
    such as sports programmes, and LP or EP for talk shows, etc. with
    relatively less movement.
    Recording
    mode
    Recording amount
    (approx.)
    Maximum recording
    time (approx.)
    XP 10 Mbps 57 hours
    SP 5 Mbps 113 hours
    LP 2.5 Mbps 225 hours
    EP 1.6 Mbps 338 hours
    FR60–FR360
    57 – 338 hours
    FR480 473 hours
  2. alicat
    alicat
    Oct 13, 2004
    92
    where did you get the user manual from?
  3. EN
    EN
    Jul 24, 2000
    267
    19
    Sofia, Bulgaria
